2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-15T16:01:51+00:00
    I received my replacement SP2 yesterday.  I reinstalled MS Office and all third party software and it seems to run fine.  I left it on last night and simply closed the cover to put it into sleep.  This morning it awoke from sleep with 100% battery, cool to the touch and the battery meter appears to be accurate. So far so good.  I will definitely be waiting to install any new firmware updates as the machine is running the way I expect it to and the if it ain't broke don't fix it mentality seems relevant here.
    2014-01-15T16:37:06+00:00
    Seriously, I exchanged my newly purchased device over Christmas, got one without the update, and has been smooth sailing since.  I won't be updating ANYTHING firmware related.
