2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-15T14:16:14+00:00
    Yes, this has happened to me with the October firmware, but not for these particular updates.
    2014-01-15T15:29:47+00:00
    Same here. I just got of the phone with Microsoft. They're sending out a replacement, but the agent said there's no way to request a new unit instead of a refurbished one. Fingers crossed.
