2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-15T02:20:43+00:00
    Well after the much awaited January 14th update, I have applied everything Microsoft had to offer from patches since the December debacle, including all that was out today.  Much to my disappointment, but not surprise, I just pulled my "cooking" surface pro 2 out of my bag from the office earlier today.  I left my desk wit 100% battery and 3 hours later it's roasting with 30% less juice (not uncommon unfortunately over the last month.)  I have stayed patient and relatively silent on this issue but this is getting to be a bit much.  I've invested much in the surface line having been an original surface RT customer and then a surface pro as well.  I now own the surface pro 2 and continue to utilize it as my primary pc/laptop in running my technology company.  I really like this product and it does not make sense how MS is handling this bug.
    I am now wondering of the long term effects on the hardware and believe that MS needs to offer some sort of replacement program or extended warranty to compensate.  If anything some "actual" knowledge of the issue, how it affects the devices, and a realistic expectation as to when it will be solved.
    2014-01-15T02:46:01+00:00
    agreed. the update did nothing. I didn't see a firmware update. For all the apologetics that defended the delay, where are you now. it's been almost a month and MSFT hasn't fixed their customers.
