2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-15T02:07:24+00:00
    I waited for weeks until a service rep promised that the hardware issue would be addressed in a firmware update today (1/14/2014). When no such update was found this morning, another rep said they are working hard on it and will release the new firmware by 3 pm PST. We all know how that went. That's the end of the line for me; I'm exchanging mine or getting a refund. I'm sure they'll promise it'll be fixed "tomorrow" but confidence is low at this point.
    2014-01-15T02:16:55+00:00
    Confidence is low is an understatement
    WHERE IS OUR FIX. These devices are EXPENSIVE and you have BROKEN THEM FOR OVER A MONTH
