2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-15T00:33:31+00:00
    I was also given a case number in case I still want to swap it after the update.  The Tech told me he was confident tomorrows firmware update would resolve the issues.
    2014-01-15T01:28:55+00:00
    One way to provide feedback to MS would be to go to the Surface Pro 2 firmware update page link provided by Mickey Segal:
    http://www.microsoft.com/surface/en-us/support/install-update-activate/pro-2-update-history
    and down at the bottom of the page for the question Did This Help?  YES or NO, answer NO, then submit feedback telling them why ("I'm looking for a January firmware update to fix the December, 2013, firmware update that messed up my Surface Pro 2..... "- or whatever).  The squeaky wheel gets the grease, so another way of (hopefully) making Microsoft hear some noise about the mess they need to fix.  There is also a Contact Us button at the top of the same page, too.  I used both options on the page and am currently #13 in a chat queue waiting for a Surface Support Tech (a phone wait is something like 37 minutes).  I typed a query as to when to expect a firmware update as the reason for my chat, wanting to make sure my SP2 is restored to 100% working order.
