2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T21:06:02+00:00
    I found on reddit (r/Surface)
    Someone posted these step, I don't know if the dism/sfc will help those who are still having issues or not, but here it is:
    1. In Command Prompt: net stop wuauserv
    2. Rename C:\Windows\SoftwareDistribution\DataStore\datastore.edb => datastore.old
    3. Disk Cleanup/System Cleanup for Windows Updates
    4. Reboot.
    5. Run Windows Update Troubleshooter
    6. Reboot.
    7. Ran in Command Prompt: sfc /scannow
    8. Reboot.
    9. Ran in Command Prompt: dism /online /cleanup-image /restorehealth
    10. Reboot.
    11. Ran Windows Update -> Firmware successful.
    2013-12-11T21:11:52+00:00
    Also have this issue.
    Though I have checked the version numbers for the different devices, and they seem to have all 'updated'. So I'm unsure which part of it failed.
    Surface Pro 2:
    • Intel HD Graphics (v10.18.10.3345)
    • Improved system stability, including minimizing full screen games.
    • Color fidelity improvements for all applications. Enhanced audio experience when connected to a Display Port 1.2 device.
    • Marvell AVASTAR WiFi and Bluetooth Driver (v14.69.24049.160)
    • Wi-Fi driver update for an improved Wireless Display experience and connectivity with Wireless Access Points.
    • Surface Type Cover 2 Firmware Update Device (v2.0.266.0)
    • Surface Touch Cover 2 Firmware Update Device (v1.0.280.0)
    • Optimized two finger track pad use.
    • Surface Pro UEFI (v 2.04.0250)
    • Surface Pro System Aggregator Firmware (2.03.0650)
    • Surface Pro Embedded Controller Firmware (23.07.50)
    • Improved Surface Cover Interaction including power-saving sleep functionality.
    Per MS Post about Update
    Seems like for me all updates got installed except Surface Type Cover 2. I have version v2.0.51.0 instead of v2.0.266.0 under Surface type cover filter device. Does anybody have this issue.
    You may want to try under Device Manager->Human Interface Device->Surface Type Cover 2 Firmware Update Device, which appears to be correct.  However, my filter device shows the same thing.  And I do have a failed installed.
    Thanks sbutter. It shows updated driver number. I was looking at the wrong place.
    Looks like the installation was successful but update history shows failed. You may want to try the suggestions from davidb1234 above. After that I got a small firmware update and I restarted the system. I guess that should be it.
    By the way anybody noticed improvement with trackpad. I am not sure as I am using bluetooth mouse from the beginning.
