2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-14T21:30:12+00:00
    Please have the courtesy to read my most recent question  and advise me on course of action. In the event of not getting any satisfaction from Microsoft I intend to take some action in relation to UK sale of goods legislation.
    It would indeed be good to get word from Microsoft as to what is going on now that the planned firmware update hasn't shown up.  But it seems that a more effective and faster route to getting this fixed is making clear to Microsoft and the wider public that more than 0.3% of users are affected by these problems.
    For many of us, however, this has been more than a nuisance than anything else, since all we've had to do is minor things, such as avoiding the sleep state and being careful about keyboards and SD cards being engaged.  Those would be a big nuisance in the long run, but are not a deal-breaker in the short run, and while we should make clear that it is a problem, we should not encourage Microsoft to drop the Surface line.
    With the first round of small tablet about 8 years ago, the first batch of Motion Computing LS800 tablets had overheating issues.  Motion got this solved after a few months, but so much fuss was made that the computer was always considered damaged goods, and small tablets were considered not ready for prime time.
    It would be a shame for the same to occur to Microsoft.
    2014-01-14T21:43:38+00:00
    For Surface Pro 1, January firmware updates are listed at http://www.microsoft.com/surface/en-us/support/install-update-activate/pro-update-history
    The corresponding page for Surface Pro 2 lists no January firmware updates:
    http://www.microsoft.com/surface/en-us/support/install-update-activate/pro-2-update-history
    It seems there are two possibilities:
    1.  Someone got confused and the updates are for Surface Pro 1, not 2.
    2.  The Surface Pro 2 updates are delayed for some reason.
    It would be good to get a comment from Microsoft.
