2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-14T19:18:42+00:00
    I repeat.
    The update check doesn't work. The update fault troubleshooter doesn't work.
    Now what do I do? A system restore? To what point?
    How about someone from bl00dy Microsoft answering the question!
    Roy
    2014-01-14T19:40:49+00:00
    Josh,
    Thank you,
    Tim
    Please have the courtesy to read my most recent question  and advise me on course of action. In the event of not getting any satisfaction from Microsoft I intend to take some action in relation to UK sale of goods legislation.
    Roy
    Where has the detailed question I posted gone?
