2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-14T19:07:51+00:00
    How disappointing - NO Firmware update - and I can confirm all previous issues with SP2 remain - my battery is stuck at 64% and not charging - only volume up & power button press will fix this - but happens again & again - so I wonder what MS are doing to fix this as they seem very 'absent' from any details regarding the fix - so, SP2 goes back to being a very expensive 'photo frame' - and I will pull out my trusty Apple MAC - will give the SP2 a few more days & if MS do not res love it - I will bin it & will not be buying again - and neither will my friend & family! - unhappy /t
    2014-01-14T19:17:21+00:00
    Same here. All previous issues still remain. SP2 nearly unusable for over a month.
     @Microsoft update for firmware ?
