2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-14T19:03:51+00:00
    I did all the updates except the 24 October firmware update, which showed up 2 days ago, and is still being offered.
    I didn't install the 24 October firmware update two days ago since I thought it would be replaced by the 14 January firmware update, but there doesn't seem to be any sign yet of a 14 January firmware update.
    I suppose it is possible that the 14 January update shows up only after you install the 24 October update, but no one seems to have a 14 January update so that seems unlikely.
    For now, I'm not installing the 24 October update.
    2014-01-14T19:04:43+00:00
    My battery idicator stays at 100 %. Wtf ...
