2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-14T18:41:07+00:00
    There are several updates to fix issues with 8.1 but no sign of the elusive FIRMWARE update.
    I have installed all updates and to test if the device would still wake up from sleep by itself, I change hibernate from sleep duration to one minute.
    I put my device to sleep and after one minute, it wakes up on its own.
    This is after I installed the 10/24 Firmware Update (103kb) that appeared after installing the 1/14 updates.
    Unfortunately no firmware update yet that fixes the auto wake problem caused by hibernating from sleep.
    Going back to hibernate for the meantime. I can't tell if the battery indicator issue is still going on.
    BTW
    My Touch Cover 2 is not recognized by Trackpad Settings windows app but the cover works flawlessly. This has been happening after installing the December firmware update so nothing to do with today's updates.
    2014-01-14T19:03:47+00:00
    UNBELIEVABLE.  All this waiting and no firmware update/fix.   You people thinking it will come out later today are mistaken.  If it isn't listed it isn't coming out this month.
    MICROSOFT HOW ABOUT AN UPDATE ON THIS?
