2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-14T18:37:47+00:00
    And this is why I sent my back, I am hoping my replacement surface turns up this week, its coming from Australia (I am in new zealand).
    Even if a release of the firmware is today I just don't trust MS to fix it without more problems, the total lack of info on the problem and a firm date on when it will be fixed.
    When I called surface support over in the US they were very careful at not giving me a confirmed date on the new/fix firmware.
    2014-01-14T18:39:44+00:00
    I just checked and there were 9 important updates available to me - at least two were for office.
    I saw the 73.5 optional windows 8.1 update too but as San just said, no firmware update yet.
