2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-14T18:10:45+00:00
    Now I can see an Update for Windows 8.1 x64-bit Systems
    Number: KB2904440
    Released: 14.01.14
    But the additional link doesn't exist:
    support.microsoft.com/kb/2904440
    (Edit: now working!)
    I am installing it right now. Could it be worse? I hope not ...
    Installed. Still working ... :D (hurray!)
    There is also another update KB2512827 with 73.5 MB.
    According to the description page it fixes numerous errors in windows 8.1.
    2014-01-14T18:20:11+00:00
    There are several updates to fix issues with 8.1 but no sign of the elusive FIRMWARE update.
