2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T19:23:41+00:00
    RESOLUTION FOR FAILED 12/10/2013 FIRMWARE UPDATE:
    1.  Open dos prompt and run:  NET STOP WUAUSERV
    2.  Delete:  C:\Windows\SoftwareDistribution\DataStore\datastore.edb
    3.  Open start menu and type DISK CLEANUP and choose CLEAN UP SYSTEM FILES.  Make sure that windows software updates are selected and perform disk cleanup.  This will take a few minutes.
    4.  REBOOT
    5.  Run windows update, all history will be gone but it will detect the firmware update again and this time it will install successfully.
    Microsoft screwed the pooch for a 2nd time here...
    This process does not work if you have reset the system back to factory defaults.  The firmware shows that it is installed, but not all of the updates are applied (wifi and graphics).  When I tried this process to see if it would install the wifi and graphics, it just tells me no updates are available.
    2013-12-11T20:10:23+00:00
    Also have this issue.
    Though I have checked the version numbers for the different devices, and they seem to have all 'updated'. So I'm unsure which part of it failed.
    Surface Pro 2:
    • Intel HD Graphics (v10.18.10.3345)
    • Improved system stability, including minimizing full screen games.
    • Color fidelity improvements for all applications. Enhanced audio experience when connected to a Display Port 1.2 device.
    • Marvell AVASTAR WiFi and Bluetooth Driver (v14.69.24049.160)
    • Wi-Fi driver update for an improved Wireless Display experience and connectivity with Wireless Access Points.
    • Surface Type Cover 2 Firmware Update Device (v2.0.266.0)
    • Surface Touch Cover 2 Firmware Update Device (v1.0.280.0)
    • Optimized two finger track pad use.
    • Surface Pro UEFI (v 2.04.0250)
    • Surface Pro System Aggregator Firmware (2.03.0650)
    • Surface Pro Embedded Controller Firmware (23.07.50)
    • Improved Surface Cover Interaction including power-saving sleep functionality.
    Per MS Post about Update
    Seems like for me all updates got installed except Surface Type Cover 2. I have version v2.0.51.0 instead of v2.0.266.0 under Surface type cover filter device. Does anybody have this issue.
    You may want to try under Device Manager->Human Interface Device->Surface Type Cover 2 Firmware Update Device, which appears to be correct.  However, my filter device shows the same thing.  And I do have a failed installed.
