2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-14T17:43:17+00:00
    No new updates yet ... :(
    2014-01-14T17:57:41+00:00
    I am so weary of this nonsense from MS
    53 pages of utter confusion later ( I haven't  read anything like all of it) and by now I have no idea where I am with a  device that I bitterly regret spending so much money on.
    Currently if I run "check for updates", the check simply runs forever without reporting anything.
    My update history shows:
    • System Firmware Update - ‎10/‎12/‎2013
    • Installation date: ‎16/‎12/‎2013 16:42
    • Installation status: Failed
    • Error details: Code 80070490
    • Update type: Important
    But
    • System Hardware Update - ‎24/‎10/‎2013
    • Installation date: ‎23/‎12/‎2013 18:19
    • Installation status: Succeeded
    and of course the by now hilariously inappropriate statement:
    These updates are released by PC manufacturers to help improve the stability and performance of PC hardware.
    Yeah, sure they do...
    So if and when the Big Fix update arrives what do I do? I'd really appreciate some advice as despite long experience of Windows (since NT 3,5) I am absolutely lost here.
    Roy
