2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-13T20:02:23+00:00
    So who volunteers to test the firmware updated expected on 14 January and tell the rest of us whether to be cautious or install it?
    2014-01-13T20:51:12+00:00
    I plan to install it as soon as it hits the airwaves.  I will report back on what my experience is, but it may take some time to determine if things are working right or not (have to let it go to sleep a few times etc.)
