2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-13T14:48:01+00:00
    Many had recommended using Hibernate in order to deal with the units waking up from shutdown or sleep. Now I've never used Hibernate before in my life, but gave it a test drive this week and I gotta tell ya it is superbly reliable at crashing nearly every application I left opened. KMPlayer, GestureKey, Firefox, Razer Synapse, etc... you name it. I wonder how many people found hibernate to do this?
    I can tell you I use hibernate and not sleep (hardly ever sleep) and my device hasn't crashed once since buying it. :S.... Then again, I'm also not affected by this Dec. bug even though I do have it installed. Well, I was once, but only once. I restarted the computer and overnight battery drain disappeared ever since. But crashing? Never had that issue before :-\
    That's the boat I'm in.  I have never had a crash with my SP2.  I'm not sure I would know what they would even look like.  I've had my SP2 'wake up' by itself, once.  And, I had a battery issue where the RED x showed up saying, No Battery.  I fixed that.  The only real thing I see is less battery life that prior to the December 10th update.  Where I was getting 9 + hours prior, I'm not getting significantly less.
    From a curiosity factor, I'd love to the configurations of the devices that have crashed.  But that has always been the situation...why do some people crash a lot and some people never do....
    2014-01-13T15:42:06+00:00
    For me, it's not a crashing issue, but the fact that the machine won't sleep, and if it does, it wakes up on it's own and drains the battery.  Also, the battery capacity reports less than capacity which fouls up the reported time left on a charge.
    My Surface is a Pro 2 with 128 gig of ram.  Nothing out of the ordinary as far as configuration goes. Only added thing is a Micro SD card in the size of 64 gig.
    I think there are multiple issues this firmware caused, mainly being the inability to sleep correctly and the crashing on resume from hibernate.  For me, hibernate was the solution as I have never experienced a crash resuming from hibernate, but obviously that is not the case for some people.
    Hopefully we'll see a firmware update tomorrow that will at least get us all back to where we were before December 10th.
    Blessings!
