2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-13T04:26:29+00:00
    Many had recommended using Hibernate in order to deal with the units waking up from shutdown or sleep. Now I've never used Hibernate before in my life, but gave it a test drive this week and I gotta tell ya it is superbly reliable at crashing nearly every application I left opened. KMPlayer, GestureKey, Firefox, Razer Synapse, etc... you name it. I wonder how many people found hibernate to do this?
    2014-01-13T06:37:14+00:00
    I can tell you I use hibernate and not sleep (hardly ever sleep) and my device hasn't crashed once since buying it. :S.... Then again, I'm also not affected by this Dec. bug even though I do have it installed. Well, I was once, but only once. I restarted the computer and overnight battery drain disappeared ever since. But crashing? Never had that issue before :-\
