2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-13T00:05:48+00:00
    I agree Phil....This device has been out for 3 months and it hasn't been reliable since it's release. The Surface 2 has  just as many  problems. If they don't get it right this time they might as well take it off the market,which wouldn't surprise me the way things are going.
    2014-01-13T03:27:15+00:00
    Hello
    Has this problem been resolved? I noticed recently that my Surface Pro 2 is warm indicating that it is working pretty hard when it should be sleeping. Battery life is now only a few hours. If an update has been released, how do I check my machine has it?
    Alex
