2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-12T21:01:56+00:00
    The new one seems to have also a different ssd. But I don't know which one is better.
    Source:
    http://www.computerbase.de/forum/showthread.php?t=1298829&p=15117173#post15117173
    2014-01-12T22:57:09+00:00
    Today I was offered a "System Hardware Update - 24-Oct-13".  This sounds like the firmware update before the 10 December one.  It is odd that it would show up 2 days before the fix was expected.
    Are others being offered this as well?
    If you made any changes to any hardware that was included in this offering, then a reload of the drivers might have occurred.  Remember, the Firmware downloads MS offers are not all firmware...sometimes its just drivers.
    For the record.....I don't think a fix is coming in 2 days.  I believe its not finished yet and won't be available until after some time
