2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-12T20:41:20+00:00
    Today I was offered a "System Hardware Update - 24-Oct-13".  This sounds like the firmware update before the 10 December one.  It is odd that it would show up 2 days before the fix was expected.
    Are others being offered this as well?
    2014-01-12T20:48:45+00:00
    Me 2 - this seems to happen if you do a 'clean disk' - at next windows update check it always re-installs the 24-10-2013 update - ifs just another example of the mess this system is in - and doing the reinstall resolves nothing but just causes more irratic behaviour with the wake,sleep & hibination.
