2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-12T01:10:45+00:00
    Here's the link to Microsoft's advanced notification of updates for this Tuesday. Nothing is mentioned for Surface Pro 2.
    https://support.microsoft.com/kb/894199/en-gb
    that is true, but then the December one didnt mention the SP2 either (that i can see):
    technet.microsoft.com/en-us/security/bulletin/ms13-dec
    They dont seem to track firmware/driver changes like they do for software updates. Hopefully something they fix in future
    This is the only page I've found with info, and it's quite out of date (doesn't mention Dec one was pulled, and doesn't have any version numbers):
    https://www.microsoft.com/surface/en-au/support/install-update-activate/pro-2-update-history
    http://support.microsoft.com/kb/2921911 is the 2013 summary and there is no mention of any firmware updates on Dec 10.  I suspect they are not listed in this article as it applies to the operating system and firmware is really not part of the OS.
    2014-01-12T07:19:18+00:00
    Thanks, sounds reassuring, hopefully still on target for this Tuesday.
