2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-11T19:25:38+00:00
    Here's the link to Microsoft's advanced notification of updates for this Tuesday. Nothing is mentioned for Surface Pro 2.
    https://support.microsoft.com/kb/894199/en-gb
    2014-01-11T21:45:15+00:00
    that is true, but then the December one didnt mention the SP2 either (that i can see):
    technet.microsoft.com/en-us/security/bulletin/ms13-dec
    They dont seem to track firmware/driver changes like they do for software updates. Hopefully something they fix in future
    This is the only page I've found with info, and it's quite out of date (doesn't mention Dec one was pulled, and doesn't have any version numbers):
    https://www.microsoft.com/surface/en-au/support/install-update-activate/pro-2-update-history
