2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-10T17:43:55+00:00
    Well I gave the shop a call yesterday and it sounds like MS new zealand will replace mine with a new one, don't know yet when I will get it back, I am hoping monday (NZ) time.
    2014-01-10T19:05:05+00:00
    ......Microsoft's service and support is abysmal and they obviously do not care about their customers.........
    I've never had anything but satisfactory customer experiences with Microsoft both on the phone and in WIndows Stores.  Haven't had to return anything and the customer reps I've spoken to haven't always had all the answers but I found them knowledgeable, going out of their way to be helpful, and always very courteous and patient with me even if I was upset about something.  I mainly called them about power issues with my Surface RT tablet such as unexpected battery discharges while in Connected Standby mode and used the toll-free number that used to be given in the This Computer Properties window (seems to have disappeared in Windows RT v8.1!!  On the calls using that number, I always seemed to get a U.S.A. rep (and I'm calling from the U.S.) and all the reps I  spoke with had a very detailed knowledge of the Surface RT hardware and software properties.  So maybe service quality changes with the times or the device but I was impressed how much support I got for the Surface RT device.
