2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-10T15:41:24+00:00
    I shipped my sp2 back at the beginning of the week. I went online to check the status of the order and all it says 4 days later is "received".  After four attempts at chat I was finally able to chat with a support person (outside the U.S.  and was told that it takes 5-7 days to process my order and another 5-7 days to ship it back FedEx ground.  Really? Your service facility is in Texas, not overseas like your call centers.
    Microsoft screws up our machines, can't be bothered to update their service orders to at least show they are processing the order and then will send it back to me via the slowest method.  Funny they sent me an overnight label to send it back.  Apparently it is not a priority to get a replacement machine back to me, after all they have my money from the purchase so I am not a priority.
    I then tried to call tech support to talk to someone.  All of the calls are routed to either India or the Philippines.  Each time I asked the call center person to provide me with a customer support number in the U.S. and each time they either routed to another oversea calls center or gave me the same phone number each time telling me they had no U.S. number.  Again. Really?  A U.S. based company has zero support staff in the U.S.
    Microsoft's service and support is abysmal and they obviously do not care about their customers.  If they did they would update their support status regularly, provide customer support that was responsive (and understandable) and get affected purchasers their replacements via overnight delivery.
    2014-01-10T16:01:39+00:00
    Hey, at least they didn't hang up on you.  When I asked if this was a U.S. center (and I knew the answer) they hung up.
