2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-08T05:02:42+00:00
    Well I have the same problem reported here, mine has gone back to store I got it from to be returned to microsoft NZ for them to look at.
    Was working fine until about the 13th December when the firmware was loaded on, in windows update it said it did not install however after checking the version numbers most of the update went in.
    Mine would turn itself on after using shut down, It would be sitting on my desk and the screen would just turn on. 3 or 4 times it did it in my bag while driving home in hot weather (it's summer in new zealand),  When it did this it would almost cook itself so have no idea if there was any damage inside the unit, Fans were going flat out and hot to the touch on the back and very warm on the front of the unit.
    It would also sometimes not go to sleep and drain the battery in about 6 hours.
    Called the support number for "surface support" and talked to a tech, he told me to do the +vol and power button for 20 seconds, the tech said this should "correct some of the issue" it just made it worst after doing this and now my battery always shows 100% had it running for 3 hours still said 100% until I plugged it in then it dropped to 99% for 1 or 2 minutes then back to 100% (did not do this before talking to tech support).  Tech support said the fix "should" be out in 8 days time but would not confirm this as a hard date.  I asked about it overheating and he said that the system is designed to turn itself off to protect itself.  Yet mine did not turn itself off and would not trust it too as it would turn itself on.
    I am hoping to get a brand new unit as I have no idea what damage has been done to the inside due to the overheating from it turning itself on (after using shut down).
    So at the moment I don't have any computer but still out $1200 while MS looks at it.
    2014-01-08T06:03:49+00:00
    yeah. got the same problem.... just asked for a refund. my device was CONSTANTLY overheating when I'm doing simple tasks such as googling or watching a youtube video. It was so bad that the battery life decreased to TWO hours...... The SP2 is my only form of portable device that I can bring to school.
    With the fact that I have no other alternative, Microsoft wants me to ship my only device to them first, wait until they receive it, and wait 5-7 business days for it to ship me a new one. I know $1200 is a lot of money, but as a corporation and to people who spend $1200, they should at least consider sending in something else so users have a loaner to work with so they aren't empty handed. Of course, I had no choice but to opt for the Advanced Exchange program, but luckily my mom has a nice credit limit so I was able to process the "new pending charge". If I had my own credit or debit card, my credit limit wouldn't even surpass that amount and I'd hate to ask my parents for money for the time being... I saved up for this device and hope that it would bring me convenience, but so far it's just been 1 month of ****....
