2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-07T20:22:30+00:00
    FYI, you won't necessarly get a 4300U if you get a replacement now. I got a replacement on the 31st from the Ontario warehouse for another unrelated problem, and it was a 4200U.
    Same here - with exact same problem - won't sleep with the TypePad 2, and SD card installed.
    Friggin idiots
    2014-01-07T21:06:23+00:00
    The updated firmware is expected Jan 14th during Patch Tuesday. See here:
    http://www.winbeta.org/news/microsoft-re-release-dec-2013-surface-pro-2-firmware-update-jan-14th
    well count me out from this update. Given past performance, I'm going to wait at least two weeks. Right now my surface is limping along. crashes, freezes now and then and randomly reboots and turns on. I have had dells, hps and Toshibas that have been more stable than surface...being made by MSFT. how this makes ANY sense is beyond me.
