2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T17:23:58+00:00
    After getting the failed firmware patch 12/10.
    I stopped the windows update server "net stop wuauserv", renamed the C:\Windows\SoftwareDistribution\DataStore\DataStore.edb" to DataStoreold.edb, restarted the update service "net start wuauserv",
    Then Ran Windows Update Troubleshooter: http://windows.microsoft.com/en-us/windows-8/troubleshoot-problems-installing-updatesThen restarted just to be sure of things, then ran disk cleanup "Clean up system files", and made sure the windows update files were selected for cleanup.After that restarted again for kicks.  And re-ran regular Windows update.
    For me the driver versions were up to date after the update, even it failed.
    So after your trick, which worked for me too, the Update was just 600kb big, but installation went smooth.
    Thank you
    2013-12-11T17:39:56+00:00
    I followed your instructions and it worked well. I had a brief moment of panic after reboot when I tried to run Windows update and it immediately gave an error. Running it again went smoothly though.
    Thanks for figuring this one out!
