2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-07T11:48:29+00:00
    This is Two-button shutdown procedure, probably the best repairing one for SP2.
    http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-pro-wont-turn-on
    2014-01-07T18:06:39+00:00
     a quick fix to this problem, which i have had since buying my Surface Pro 2 in Dec. Not sure why this works but i found it online.
    power down the surface, then press and hold down the Volune + button and the power button together for about 15 seconds. the screen will flash as couple of times then after 15 seconds, turn on the Surface as normal.  this worked for me......
    for me, this is the #1 troubleshooting step.  With the Surface Pro its a  manual shutdown.  With the SP2 its the 2 step shutdown.
    Fixes a lot of issues with updates, though not the December 10th fiasco.
