2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-07T05:43:29+00:00
    FYI, you won't necessarly get a 4300U if you get a replacement now. I got a replacement on the 31st from the Ontario warehouse for another unrelated problem, and it was a 4200U.
    2014-01-07T08:58:28+00:00
    a quick fix to this problem, which i have had since buying my Surface Pro 2 in Dec. Not sure why this works but i found it online.
    power down the surface, then press and hold down the Volune + button and the power button together for about 15 seconds. the screen will flash as couple of times then after 15 seconds, turn on the Surface as normal.  this worked for me......
