2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-06T19:39:53+00:00
    If Microsoft is doing replacements does this mean: 1. There is some permanent damage created by the 10 December firmware update? 2. Microsoft is replacing computers even though they know that any damage will be fixed by the 14 January update? 3. Those offering the replacements don't understand what is going on. It seems like there is at least one crucial fact we don't know.
    They definitely know what's going on; the rep even mentioned that the problem will be fixed by Jan 14. I was just a bit persistent that I needed a working device now and I don't think Microsoft wants to **** off owners of their flagship tablet.
    2014-01-07T05:18:33+00:00
    I have just collected my replacement Surface Pro 2 From the retailer in Adelaide, South Australia, where I returned the bricked unit last month. They were then out of stock, hence the delay in getting the replacement. This new unit has the i5-4300U CPU, so I'm not now complaining about the delay!
    I had managed to get my original SP2 limping along enough to allow me to do a reset. I then attempted to update without installing the version of the Oct firmware offered at that time - the updates downloaded, but didn't install. So I let the firmware update install. Most of the other updates installed, but it shut down before completing. They finished installing the next time I managed to get the unit running, but then it went into an endless loop of booting into the UEFI screen when I attempted to restart. That's what prompted me to return it for a replacement.
    Windows update offered me the October 24 Firmware update on this replacement unit. IIRC the Oct FW update I was offered previously was much smaller than what is now offered. The firmware now offered is 28.9 MB
    I can report that the the firmware update, and the other 26 updates, installed without any hiccups.
    I have shutdown and restarted successfully - YAY
