2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-06T16:34:20+00:00
    Microsoft support is doing advance replacement for Surface Pro 2 devices for this issue. If you'd like an upgrade to the i5-4300U without any downtime on your Surface, you might want to consider this before the patch hits.
    2014-01-06T18:51:17+00:00
    If Microsoft is doing replacements does this mean:
    1.  There is some permanent damage created by the 10 December firmware update?
    2.  Microsoft is replacing computers even though they know that any damage will be fixed by the 14 January update?
    3.  Those offering the replacements don't understand what is going on.
    It seems like there is at least one crucial fact we don't know.
