2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-06T05:43:39+00:00
    The updated firmware is expected Jan 14th during Patch Tuesday. See here:
    http://www.winbeta.org/news/microsoft-re-release-dec-2013-surface-pro-2-firmware-update-jan-14th
    Excellent!  thank you very much!
    This article seems to be getting its information from this thread, so it doesn't seem to be adding much except that it is out there and hasn't been denied.
    got off the phone with MS Support today, confirmed Jan 14th... for the time being.
    2014-01-06T14:54:53+00:00
    I have tried this only to find my SP2 back on after shutdown. This happened when the type cover was connected.  If I shutdown without the type cover, it stays off.  Hibernate seems to work most of the time.
    These problems defeat the purpose of having a mobile device.  Sending it back tomorrow for a replacement.
    Various posts suggest that Sleep, the Type Cover and the SD card reader are part of the problem.  So here is what I've been doing that addresses all these issues:
    1.  Don't use the power button or closing the Type Cover to shut down.  Always shut down using explicit software commands to Shut Down, not Sleep.  From the Desktop use the Windows button right click "Shut down" option, or from the Metro interface use Settings Charm | Power | Shut down.
    2.  Never shut down with the Type Cover attached.
    3.  Never shut down with anything in the SD card reader.
    This protocol is undoubtedly overkill, but it does work and it is not a big bother to do for the next week or so.
    Microsoft could probably issue a less severe protocol, but they seem to be too dysfunctional to do so, or may know of other problems not solved by this protocol.
    Hopefully when Microsoft has a new leadership team they will function better, but this firmware episode provides a case study of what is wrong currently.
