2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-05T22:42:49+00:00
    Just got off a call with Surface support team and they confirmed that the new firmware will be released January 14th. Interesting the support team have been told by Microsoft that the botched December firmware only affected 3 in 1000 devices, needless to say I nearly fell off my chair when they said that!
     That really worries me...that they may not be addressing the full scope and severity of the problem. 0.3% sounds like their closing their eyes to the extent of the problem, or playing games with the numbers so the big wheels don't fire them.
    I have trouble believing that it is that low. I had to replace my SP2 around the time that the new firmware was available. I had both SP2's for a few days. Both of them exhibited the same sleep issues after the firmware update. They would wake up randomly and they won't sleep sometimes.
    I've been getting "...high call volume..." and long holds from Microsoft Store's Surface Tech Support for a couple of days now. It is hard to believe those figures.
    2014-01-06T03:43:28+00:00
    The updated firmware is expected Jan 14th during Patch Tuesday. See here:
    http://www.winbeta.org/news/microsoft-re-release-dec-2013-surface-pro-2-firmware-update-jan-14th
    Excellent!  thank you very much!
    This article seems to be getting its information from this thread, so it doesn't seem to be adding much except that it is out there and hasn't been denied.
