2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-05T21:30:29+00:00
    The updated firmware is expected Jan 14th during Patch Tuesday. See here:
    http://www.winbeta.org/news/microsoft-re-release-dec-2013-surface-pro-2-firmware-update-jan-14th
    2014-01-05T21:48:45+00:00
    Excellent!  thank you very much!
