2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-05T18:45:22+00:00
    Me too in response to SanHolo's Post of Jan 5
    I have issues with my type cover coming on (lights up) randomly after sleep.
    My battery indicator remains at 100% when not connected to power... it lies/is stuck.
    My Surface Pro 2 heats up really quickly when not plugged into power.
    When I first discovered the problem, it was in it's case and was burning up hot!
    Thanks for posting about the lights.  It's true!  Maddening!  Makes me think I'm being hacked.
    2014-01-05T21:27:41+00:00
    To ensure the best experience for our customers during the holiday season, we have taken steps to remove the update for Surface Pro 2 that was previously published through Windows Update on December 10^th^, 2013. We are working to release an alternative update package after the holidays.
    Josh
    Any news yet on the fix to the firmware update?  still having problems here, and there has been no updates other than a few security updates.
    THE SEMESTER STARTS TOMORROW PLEASE HELP
