2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T16:22:52+00:00
    RESOLUTION FOR FAILED 12/10/2013 FIRMWARE UPDATE:
    1.  Open dos prompt and run:  NET STOP WUAUSERV
    2.  Delete:  C:\Windows\SoftwareDistribution\DataStore\datastore.edb
    3.  Open start menu and type DISK CLEANUP and choose CLEAN UP SYSTEM FILES.  Make sure that windows software updates are selected and perform disk cleanup.  This will take a few minutes.
    4.  REBOOT
    5.  Run windows update, all history will be gone but it will detect the firmware update again and this time it will install successfully.
    Microsoft screwed the pooch for a 2nd time here...
    2013-12-11T16:57:39+00:00
    This worked for me as well.
