2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-05T15:20:53+00:00
    For me it's more a factor for staying productive. I have multiple apps and windows open, I'd rather return to my PC and continue where I left off rather than shutting down. But it's a fair point, I don't think a few weeks of hibernations will adversely effect the SSD too much, judging by these tests.
    "Ever wonder how long your shiny new SLC SSD will last? It's funny how bad people are at estimating just how long "100,000 writes" are going to take when spread over a device that spans several thousand of those blocks over several gigabytes of memory. Not to mention even newer drives that can take even more of a beating before going down"
    So even with continuous writes @6Gb/s it would take a year for a 256Gb drive to die. We won't be getting close to that with our devices, but of course - each to their own :)
    Additionally I believe it's only the documents and applications that are currently in memory that get written to disk. My SP2 appears to power down rather quickly, if it had to write 8Gbs worth of RAM content to disk it would take considerably longer surely?
    That may be true.  Looking about, it does seem that, somehow, hibernation only saves open apps, documents and system settings.  I suppose they mean all "in use" memory is saved to the hibernate file?  Since the hibernate file is the same size as total RAM, I'm guessing a lot of that file is rewritten over and over.
    I was just putting the hibernate/SSD info out there for those that were not aware.  :)
    2014-01-05T15:29:13+00:00
    Always worth having the discussion, thanks for pointing that out :)
    Puts my mind at rest somewhat, just hope Microsoft squash ALL the bugs that were introduced and not just the sleep issue!
