2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-05T14:44:51+00:00
    I have tried this only to find my SP2 back on after shutdown. This happened when the type cover was connected.  If I shutdown without the type cover, it stays off.  Hibernate seems to work most of the time.
    These problems defeat the purpose of having a mobile device.  Sending it back tomorrow for a replacement.
    I'm not relying on the power button or the type cover to shut down the computer.  I'm explicitly shutting down using the Metro or Desktop options.
    I agree that doing so would be an unacceptable restriction in the long run, but doing so for a few weeks until a bug fix is issued is far less trouble than configuring a new computer.
    If this is all it takes as a workaround, it is surprising that Microsoft doesn't issue such advice.  In the first few weeks after the 10 December firmware update I spoke to two Microsoft representatives, and they were completely unaware of the firmware problem.  It sounds like now they know about the problem but are giving silly advice.  When Microsoft was run by the original team of techies they didn't act this ineptly.
    2014-01-05T14:58:30+00:00
    For me it's more a factor for staying productive. I have multiple apps and windows open, I'd rather return to my PC and continue where I left off rather than shutting down. But it's a fair point, I don't think a few weeks of hibernations will adversely effect the SSD too much, judging by these tests.
    "Ever wonder how long your shiny new SLC SSD will last? It's funny how bad people are at estimating just how long "100,000 writes" are going to take when spread over a device that spans several thousand of those blocks over several gigabytes of memory. Not to mention even newer drives that can take even more of a beating before going down"
    So even with continuous writes @6Gb/s it would take a year for a 256Gb drive to die. We won't be getting close to that with our devices, but of course - each to their own :)
    Additionally I believe it's only the documents and applications that are currently in memory that get written to disk. My SP2 appears to power down rather quickly, if it had to write 8Gbs worth of RAM content to disk it would take considerably longer surely?
