2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-05T14:27:08+00:00
    With hibernation you get your open programs and docs and you just resume whatever you were doing. I've always used it in all my computers.
    2014-01-05T14:32:28+00:00
    I have tried this only to find my SP2 back on after shutdown. This happened when the type cover was connected.  If I shutdown without the type cover, it stays off.  Hibernate seems to work most of the time.
    These problems defeat the purpose of having a mobile device.  Sending it back tomorrow for a replacement.
