2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-05T14:12:58+00:00
    Have you tried avoiding sleep - explicitly shutting down instead of using sleep and not depending on the power button or placement of the type cover to turn it off?  This seems like it has stopped any problems for me.  It is a bother, but only a small bother, particularly since it is temporary.
    If this is all it takes to avoid problems it is remarkable that Microsoft hasn't issued instructions to do this.
    Hi Mickey,
    Yes, I've followed the advice in this thread and switched to hibernate, avoiding sleep entirely. This has temporarily solved the issues, I'm sure shutdown would also achieve the same result.
    I was just wondering if others were experiencing the same issues with ACPI within the System process using CPU following a sleep cycle and the Type Cover having power fluctuations..
    2014-01-05T14:24:41+00:00
    Hi Mickey,
    I wonder how much "wear and tear" your SSD is enduring with repeated hibernations?  Every time you hibernate, you're writing 4 or 8GB of data to your SSD.  That's a lot more writes than normal.  There are a couple "rules of thumb" with SSD's -- one is to turn off disk defrag (as it causes extensive unneeded writes to the SSD) and the other to turn off hibernation (for the same reason).  Both can lessen the lifetime of your SSD.
    Given the speed of SSD, I wonder if it's any faster start from hibernation or to just boot up normally?
