2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-05T00:39:30+00:00
    Just got off a call with Surface support team and they confirmed that the new firmware will be released January 14th. Interesting the support team have been told by Microsoft that the botched December firmware only affected 3 in 1000 devices, needless to say I nearly fell off my chair when they said that!
     That really worries me...that they may not be addressing the full scope and severity of the problem. 0.3% sounds like their closing their eyes to the extent of the problem, or playing games with the numbers so the big wheels don't fire them.
    I have trouble believing that it is that low. I had to replace my SP2 around the time that the new firmware was available. I had both SP2's for a few days. Both of them exhibited the same sleep issues after the firmware update. They would wake up randomly and they won't sleep sometimes.
    Maybe it's 0.3 percent of those with the upgraded cpus Lol !  :-(
    2014-01-05T01:24:40+00:00
    Not likely. Mine is a 4200 and it has the same problems
