2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-04T23:36:07+00:00
    Just got off a call with Surface support team and they confirmed that the new firmware will be released January 14th. Interesting the support team have been told by Microsoft that the botched December firmware only affected 3 in 1000 devices, needless to say I nearly fell off my chair when they said that!
     That really worries me...that they may not be addressing the full scope and severity of the problem. 0.3% sounds like their closing their eyes to the extent of the problem, or playing games with the numbers so the big wheels don't fire them.
    I have trouble believing that it is that low. I had to replace my SP2 around the time that the new firmware was available. I had both SP2's for a few days. Both of them exhibited the same sleep issues after the firmware update. They would wake up randomly and they won't sleep sometimes.
    2014-01-05T00:22:25+00:00
    Gee... I had thought the randomly waking up was the NSA spying on us, with the Surface's front and back cameras and mike!  ;)
    I agree with you though... it seems like it would be a higher number due to the automatic update default settings.
    I figured that it's possibly cheaper for them to swap equipment than to pay the overtime for all the people to do the fix on the glitch.   ...   As long as it doesn't hurt sales (and since they're oversold anyways)...
    I've been holding out for the patch thinking it was going to be Jan 2nd-ish.   Now hearing that it's the 14th,  I'm rethinking about it.  I can't unplug without this thing going in a high fever!
