2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-04T01:36:29+00:00
    The problem is that it's been almost a month and no time frame.  I just returned mine.  The KS for everyone's help. Good luck
    2014-01-04T02:34:26+00:00
    One thing folks should of course realize is that posts in a support forum are always gonna be complants.  It's quite possible and probable that the majority of people are happy with the device and are seeing no issues.
    Anyone remember those old Steve Martin SNL skits?  "Naaaaaah"
    Most people who have the problem probably assumed it's a hardware problem and asked for a replacement rather than complaining here.
    It's plausible that the shortage of Surfaces is caused not by it being popular, but rather by it having a high failure rate.
    My friend in the States asked me to try installing the most recent update, because it was being weird. So I did, and everything went haywire. Almost certainly, anyone that installed the update before Microsoft pulled it was hit.
