2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-03T22:36:17+00:00
    I just did a chat with tech support and they also confirmed the January 14th firmware release will fix the issues.  The rep said he has a SP2 with the same issue as well.
    Why wouldn't Microsoft officially announce the fix instead of just letting us just hang here waiting for news.
    2014-01-03T22:52:10+00:00
    Same reason why Apple never admits to anything being wrong until the fix is released.
    Plus, the fix may still be in testing, so why publicly commit to a date when they may not be able to meet that date?
    Hopefully, by the 14th, you guys will have a fix.
