2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T15:50:45+00:00
    same problem here , firmware update fails and wont let me retry
    2013-12-11T16:13:30+00:00
    After getting the failed firmware patch 12/10.
    I stopped the windows update server "net stop wuauserv", renamed the C:\Windows\SoftwareDistribution\DataStore\DataStore.edb" to DataStoreold.edb, restarted the update service "net start wuauserv",
    Then Ran Windows Update Troubleshooter: http://windows.microsoft.com/en-us/windows-8/troubleshoot-problems-installing-updatesThen restarted just to be sure of things, then ran disk cleanup "Clean up system files", and made sure the windows update files were selected for cleanup.After that restarted again for kicks.  And re-ran regular Windows update.  After that it downloaded the firmware patch and installed with zero issues.Perfect Device version matchup in device manager.Hope it helps someone.
    Based on your suggestion I just did disk clean up making sure windows update files selected and restarted.
    After restart windows update found update and installed successfully.
