2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-03T21:15:41+00:00
    Just got off a call with Surface support team and they confirmed that the new firmware will be released January 14th. Interesting the support team have been told by Microsoft that the botched December firmware only affected 3 in 1000 devices, needless to say I nearly fell off my chair when they said that!
     That really worries me...that they may not be addressing the full scope and severity of the problem. 0.3% sounds like their closing their eyes to the extent of the problem, or playing games with the numbers so the big wheels don't fire them.
    2014-01-03T22:14:58+00:00
    I just did a chat with tech support and they also confirmed the January 14th firmware release will fix the issues.  The rep said he has a SP2 with the same issue as well.
