2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-03T20:45:40+00:00
    Hey folks.. so I contacted Surface support via chat... They agreed to send me a NEW replacement Surface for free.  I made sure to double check that the replacement would not be a refurb.
    I explained the issue with the firmware and the fact that I had previously done every and anything I could to troubleshoot it... as well as my concern about the overheating.
    They would not let me buy complete care at the time because I am apparently just past the 45 day window, which sticks.  You can, however, purchased an extended warranty to go along with the 1 year limited warranty.
    All current Surface Pro 2's are covered for this under the current limited warranty and warrant a full replacement.  I would recommend setting that up ASAP.  You will likely get the new processor as well.
    I did the same last night and am sending my Pro 2 back on Monday for a replacement.  Just received the FedEx shipping label via email.  5-7 days for a new one to arrive.
    2014-01-03T21:04:02+00:00
    I also did this and ordered a new one for exchange. Hopefully they send a new surface pro 2 and not a repaired one. Otherwise I have to send the new one back again.
