2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-03T16:17:32+00:00
    One thing folks should of course realize is that posts in a support forum are always gonna be complants.  It's quite possible and probable that the majority of people are happy with the device and are seeing no issues.
    Anyone remember those old Steve Martin SNL skits?  "Naaaaaah"
    yes like one of my friends who's scared stiff of computers and hadn't turned his SP2 on since he bought it. He hadn't run into any issues.
    2014-01-03T18:31:56+00:00
    Hey folks.. so I contacted Surface support via chat... They agreed to send me a NEW replacement Surface for free.  I made sure to double check that the replacement would not be a refurb.
    I explained the issue with the firmware and the fact that I had previously done every and anything I could to troubleshoot it... as well as my concern about the overheating.
    They would not let me buy complete care at the time because I am apparently just past the 45 day window, which sticks.  You can, however, purchased an extended warranty to go along with the 1 year limited warranty.
    All current Surface Pro 2's are covered for this under the current limited warranty and warrant a full replacement.  I would recommend setting that up ASAP.  You will likely get the new processor as well.
