2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-03T16:00:09+00:00
    Just got off a call with Surface support team and they confirmed that the new firmware will be released January 14th. Interesting the support team have been told by Microsoft that the botched December firmware only affected 3 in 1000 devices, needless to say I nearly fell off my chair when they said that!
    Makes sense, there are less than 150 users in this forum.
    if errors < 150 then
    {begin}
       ignore;
       treat as annoyance;
    {end}
    Let's hope it fixes my screen brightness = 100% upon login and csrss.exe hogging CPU with SDcard inserted after boot.
    Hmm - that's just a "guess" on their part.  There are many who have not even called, given up, haven't noticed, stay plugged in, etc.
    2014-01-03T16:07:48+00:00
    One thing folks should of course realize is that posts in a support forum are always gonna be complants.  It's quite possible and probable that the majority of people are happy with the device and are seeing no issues.
    Anyone remember those old Steve Martin SNL skits?  "Naaaaaah"
